Who's online: bloodog, Guests: 190
  • Evo Wide Posts: 169
    Stock Poster Evo Wide
    27 Nov 2019 08:59 PM
    I do a few long trips and was wondering if there are any floorboards and controls that will fit a 93 Wide Glide?
  • Ken in Cairns Posts: 635
    Cairns FNQ
    Performance Poster Ken in Cairns
    28 Nov 2019 11:33 AM
    There are genuine HD ones for mine a 2012, but they should be the same.
    Expensive from HD, $230 if I recall, I'm thinking of going for the switchblade type of peg with the swing out heel rest.
    Ken
    Cairns FNQ
    30 Nov 2019 11:44 AM
    Not quite the same ones Wideglider.
    The link for the switchblade pegs is below, the swing wing ones are more of a swing out hwy peg but another option.
    https://www.kuryakyn.com/products/623/switchblade-pegs
  • Mono Posts: 12
    Qld
    Stock Poster Mono
    30 Nov 2019 04:49 PM
    Quoting Ken in Cairns on 30 Nov 2019 11:44 AMedited: 30 Nov 2019 11:44 AM
    Ken in cairns , I have a set of them in cairns,  that I'll never use if you interetsed pm me
    30 Nov 2019 05:15 PM
    I would prefer proper floorboards, as its an EVO I have heard EVO FLH ones should fit?
    Cairns FNQ
    30 Nov 2019 07:50 PM
    PM sent Mono.
    The dealer should be able to check on the fitment years Evo Wide.
    02 Jan 2020 10:34 PM
    Quoting Ken in Cairns on 30 Nov 2019 07:50 PMedited: 30 Nov 2019 08:01 PM
    PM sent Mono.
    My local dealer did not even know an oil filter for an Evo waa different to a Twin Cam.
© 2020 - 1.0.4.2
